Plotting 2 arrays
Maybe you also need an input for m and b. What is the error message you get when you click the broken run buttn?
Message 41 of 52
(984 Views)
On the error list under  "Show warnings", it had this :  Formular Node: Undefined variable
Under details, it had this: Error on line 1 is marked by a '#' character: " y1 = x^3+X#^2 +5; y2  = mx+ b; "
Message 42 of 52
(981 Views)
Why don't you show us your code. Do you have inputs for "m" and "b"?
Message 43 of 52
(979 Views)
Can you tell me how to paste a code on a forum like this one?. I don't have separate imputs for m and b.
Message 44 of 52
(977 Views)
Well, do you think LabVIEW is clairvoyant. How should the formula know what values to use for m and b if you don't tell it??? 😮
Just add these two inputs and all will be well, see picture.
Below the window where you compose the message is a button to add attachments. It should be clear how to use it. 🙂
Message Edited by altenbach on 05-27-2008 04:50 PM
Message 45 of 52
(974 Views)
Thanks.
Message 46 of 52
(961 Views)
Hi altenbach,
I finally got around to repeating that formular node problem but the code still gives an error message like it did earlier. I've attached the code for you to see.
Message 47 of 52
(938 Views)
Please Ignore my post. I just figured out why the code wasn't executing. I had an upper case X in formula node while the input was a lower case x.
Thanks again
Message 48 of 52
(937 Views)
Altenbach,
I have another question. This time, it is with Case structures. I'm trying to build a calculator VI that will perform more than 3 operations but the case structure would not permit more than two operations. This is not a boolean case where you can only do True and False. Here is the problem below:
Build a VI that functions like a calculator. On the front panel, use numeric controls to input two numbers and a numeric indicator to display the result of the operation (Add, Subtract, Divide, or Multiply) that the VI performs on the two numbers. Use a slide control to specify the operation to perform.
I used a vertical numeric slide control as the case selector as specified in the problem but when I wired that slide contol to the case structure, it would only allow two cases of 0(default) and 1.  I suspect it has to do with the slide control but I don't know how to fix it. I'll like your opinion and suggestions.
Message 49 of 52
(922 Views)
Again, this is a new problem, so you should start a new thread instead of posting it with the unrelated title of "plotting 2 arrays".
You can right-click on the case structure and add as many cases as you want. 🙂
Check the labview help.
Message 50 of 52
(910 Views)
