03-30-2008 08:36 PM
03-30-2008 08:51 PM - edited 03-30-2008 08:52 PM
03-30-2008 08:55 PM
03-30-2008 09:23 PM
03-30-2008 09:29 PM
I have ttached my program, it may seems too lengthy
In that program from Frame 2 I will get an array and from 3 i will get the other array, i need to plot between these two( i am doing this bit in Frame 4)
Please help me with this
03-30-2008 10:43 PM
So, you want an XY Graph? You want to plot one array versus another? Then wire up your bundle function to an XY Graph. You don't have anything wired to it right now.
p.s. There's absolutely no reason to use the sequence structure in your program. It's just making it hard to read.
03-31-2008 12:08 AM
Thanks Everyone
Dennis I have wired the bundle to XY Graph, the output waveform is not correct
03-31-2008 01:19 AM - edited 03-31-2008 01:22 AM
03-31-2008 03:28 AM
Thanks very much
The reason i repeated 3 times is the signal which i have named as torque is going to be acquired to from test.
Theta is the position information from sincos and i have to plot that with torue signal,so the output is something like the torque signal.
03-31-2008 10:55 AM
