07-15-2014 08:28 AM - edited 07-15-2014 08:28 AM
Hi everyone
I have two signals say A and B. Both are in waveform format . Both signals varies with time, but have different sampling rates.
after the measurements are made, i need to plot signal A vs Signal B. How can this be acheived.
07-15-2014 08:37 AM
Just yesterday we had a very similar discussion here!
07-15-2014 08:45 AM
thanks gerdw ,
does the method mentioned in that post works with waveform graphs also. there its xy graphs right?
07-15-2014 08:50 AM - edited 07-15-2014 08:51 AM
djac91 wrote:does the method mentioned in that post works with waveform graphs also. there its xy graphs right?
Waveform graphs require that the data has equal spacing in the x (or time) dimension).. If you graph two random signals against time, the result will generally not be linear in x, so the answer is no. A waveform graph will not work. Of course you could use similar code to graph two different waveforms against each other, but you need an xy graph to display the result.
What kind of problem are you trying to solve?
07-15-2014 08:50 AM
07-15-2014 09:19 AM - edited 07-15-2014 09:20 AM
Thanks for the suggestions
