10-01-2016 12:48 AM
Hi, I would like to plot the angular position of two motors (X,Y) in a single graph. It means plotting the angular position of motor X along x-axis & angular position of motor Y along y-axis in LabVIEW. Can anyone suggest me any VI, or how to implement it in LabVIEW.
10-01-2016 01:04 AM
-The XY graph accepts a cluster that contains an x array and a y array. Refer to the (X and Y arrays) Single Plot graph in the XY Graph VI in the labview\examples\general\graphs\gengraph.llb for an example of a graph that accepts this data type.
Ref more: http://zone.ni.com/reference/en-XX/help/371361J-01/lvconcepts/types_of_graphs_and_charts/
10-01-2016 02:20 AM
I have already gone through this link but couldnt find any solution. I want to know weather from the graph a list of array can be taken or not?
10-01-2016 02:39 AM
Could you explain a bit more?
-The array input which you provide to Y-axis of Two graphs have to be used as X-array and Y-array for the graph( This is what i understood from your question).
-Now, what do you mean by
reshmi.0989@gmail.com wrote:I want to know weather from the graph a list of array can be taken or not?
10-01-2016 02:54 AM
ok..let me explain. From motor X, I can aquire its signal by DAQ Assistant & display its angualr position in a graph, where I am plotting its angualr position w.r.t time. Similarly for motor Y. Now in my new graph I want to plot along x-axis..will be motor X position & motor Y position along y-axis. I have already attached a file peviously for yours simplicity.
Also you suggested to generate an array & cluster..so I asked that from where to generate array?
10-01-2016 03:05 AM
10-01-2016 04:07 AM
I have LabVIEW 11 version, & cannot find the link path provided by you.
10-01-2016 04:35 AM
10-01-2016 05:04 AM
If you are getting an array of X and Y values you can bundle and feed for XY Graph Node.
10-03-2016 04:47 AM
After aquiring the signal grom DAQ Assistant, I am getting the angular position of both the motors. This angular position is depicted both in numeric indicator & its corresponding graph. Now will I generate an array of X & Y values from this motors to be feed into bundle.
