Plot a waveform from a string
Hi everyone, i've to plot a waverform from a string (like this : +1.328546E-13A,-003.1000,+6.898991E-14A,-003.0000,+4.529815E-14A,-002.9000,...) and then save the data into a file.txt.
The second value(-003.1000,-003.0000,-002.9000....) has to be the X axis and the first one(+1.328546E-13A,+6.898991E-14A,...) the Y axis.
The string comes from a picoammeter and i'm using a serial connection.
I'm working with labview SE 2012.
Does anyone could help me?
Message 1 of 8
(4,459 Views)
Hi francesco,
in LabVIEW you would convert your string to an array using SpreadsheetStringToArray function. Afterwards you decimate your array into 2 arrays and use one for X values, the other for Y values.
When you use SignalExpress you should post in the SignalExpress forum!
Message 2 of 8
(4,446 Views)
Hi Gerd, thank you for your help.
I think i'm in right forum, i don't use any kind of signal Smiley Wink
Hovever...now the problem is saving the data.
I found Write to Spreadsheet file  and Write to measurement file helpful for me but not for All.
The second one is almost perfect but i'm not able to rename the headers.
Wath i want is somenthing like this (see test2 attached file)
Thank you!! Smiley Happy
Message 3 of 8
(4,391 Views)
That looks like a simple "write to text file to me". You could just use said function, use the "concatenate strings" with the headers you want, followed by the data separated by tab and carriage return.
Message 4 of 8
(4,383 Views)
Hi Daikataro
thank you for the answer.
The problem in that case is how to format the incoming string. I receive data like this (+1.645710E-14,+000.0000,-4.144607E-15,+000.1000,-2.427935E-17,+000.2000,-1.650574E-14,+000.3000,-5.049865E-14,+000.4000,-3.504731E-14,+000.5000,-9.273024E-14,+000.6000,-1.174499E-13,+000.7000,-8.655032E-14,+000.8000,-8.552034E-14,+000.9000,-5.358891E-14,+001.0000,-1.081800E-13,+001.1000,-1.040601E-...)
and i'm not able to separate the data in two columns..then for the header i understood what to do.
Message 5 of 8
(4,378 Views)
Use SpreadsheetStringToArray to convert your string to an array!
Message 6 of 8
(4,369 Views)
@francescof4 wrote:
Hi Daikataro
Hi find the attached snippet which will log the input into the required format txt file.
Hope this helps
Kudos Welcome 🙂
Certified LabVIEW Developer
Best LabVIEW Programmer @NIDAYS 2015
Message 7 of 8
(4,339 Views)
Accepted by topic author francescof4
Thank you for the help
Here is my solution maybe someone could need it
Message 8 of 8
(4,269 Views)
