05-23-2017 07:24 PM
I am trying to get the plot name of a digital line on the mixed signal graph. The line is under the group, digital. I cant seem to find a node to give me this value.
05-31-2017 05:30 PM
Hi
If you only need to extract the Plot Name, you could use a property node to do so. Right click your Mixed Signal Graph on the Block Diagram, then select Create>Property Node>Plot>Plot Name. That will display the first Active Plot it finds (by default is 0). So you will need to create a For Loop that changes the Active Plot (Using another Property Node>Active Plot , then right -click it and set it to "Change to write"). Lastly, output an array of strings from each Plot.Name available. It should look like the image:
Hope you find this useful!
