10-16-2012 04:27 PM
Hi!
I want to do the program of 1.vi but I only can do ohleds.vi
How I can that my program do the same that the other one?
10-16-2012 04:42 PM
This is basically the same question you are asking in your other thread. Don't create a new thread. You were already being helped there.
Now it is time for you to try programming something for your homework project.
(Here's a tip: Shift Registers can be your friend.)
10-16-2012 04:49 PM
Thanks for suggestion. And sorry for apoen a new thread.
10-16-2012 05:54 PM
These are great exercises!
After studying the other problem you should have no problems figuring this one out. Take the challenge!
10-20-2012 05:28 PM
Hi! I need help again, with a 2D array LEDs, Can you tell me how do this (thenew.vi)? I only can do that the leds starting of center.
10-20-2012 07:02 PM
This is very similar to your other question. I would suggest trying something first and posting that. In reality, you should be able to take the code from the other program and just modify it slightly. It seems you are not trying anything on your own first, which you will find makes people fairly unwilling to help. It isn't out job to do the problem for you.
