02-27-2015 03:39 AM
my laptop network adapted is Realtek family which supports up to 100 Mbps
but the USRP ethernet cable is gigabit
so it's not detected by my laptop
what can i do
02-27-2015 03:27 PM
You need to meet the hardware requirements. Software-defined Radio necessarily runs at "radio-like frequencies", so if the NIC in your laptop (and possibly your laptop, itself) is not fast enough, you'll need to get better/faster hardware.
BS
02-27-2015 03:30 PM
02-28-2015 05:11 AM
i am sorry denis but it's just really urgent
so a switch 10/100/1000 will solve the problem or not ?
02-28-2015 12:02 PM
I think what Dennis was trying to tell you is that USRP is a pretty technical topic, and you are more likely to find "experts" on the USRP forum than on the general LabVIEW forum. As I understand it, the USRP standard specifies pretty high transfer rates between the USRP hardware and the Host -- if your Host does not meet the minimum requirements, it probably will not work. However, I am not an expert on this topic -- go ask on the USRP forum here.
BS
