05-15-2010 06:25 AM
Dear members!
Please help me with this!
I'm a student on a Bsc course, would like to use this for animation in homework project.
Yours Gergo
Solved! Go to Solution.
05-15-2010 06:28 AM
05-15-2010 06:52 AM
Dear Adnan!
There is a .vi among the examples called force mass-spring-damper in LV2009.
This contains an animation where the an animated object (car) is given by a picture constant. I would like to make a similar animation, but I couldn't input the picture constant.
How can I add it?
05-15-2010 07:03 AM
I don't have the toolkit needed for that example on this machine. But, I believe the following KB article should answer your question:
How Can I Programmatically Insert An Image Into A Picture Control and Resize The Control?
Let us know if it doesn't.
05-15-2010 07:42 AM
Thanks a lot for Your help Anan!
This is the solution to import a picture, after that a constant with the image could be created too!
Respects
Gergo
