06-06-2014 12:40 AM
Hi Everyone,
I am having a lot of trouble to use the network published shared variable with a picture.
I always receive the message Unable to locate the shared variable in the SVE,
What is supposed to go into the chain \\<machine-name\<process>\<variable> for process name?
How should I configure it?
Best Regards,
06-09-2014 05:53 AM
Hi Olivioloyer,
Does your variable show up in the Distributed System Manager? (after deployment)
Does your VI work if you use a Shared Variable Node instead of the API?
06-09-2014 07:36 PM
Hi nick,
Thanks for your answer and for your help,
No I cannot see the variable in the distributed system manager,
Nor my VI works with a Shared variable node, see attached screenshots.
Although I found a more complex but functionning solution transmitting over TCP, I would still be interested to find out why it does not work with shared variables.
Best Regards,
