Phase/Time delay between two modules and correct it in the software?
How can I find the phase delay between a bridge module (1 strain gauge) and a voltage module (1 potentiometer)  and correct it in the software?
Cheers.
Mik
(2,758 Views)
One card is 24-bit resoltion , the other is 16-bit.
(2,751 Views)
Wire the same signal to both devices. Choose a waveform which will allow you to measure the delay with sufficient precision. If the devices have multiple channels, you also need to account for inter-channel delays.
Lynn
(2,738 Views)
can the 24-bit be converted to 16-bit to match the other card?
(2,678 Views)
Why? What does the amplitude resolution have to do with timing?
What are your two different modules? If you can share a clock, the acquisitions will be in sync.
(2,664 Views)
