>> If you could post a simplified version of your code, maybe we can suggest a few hints.
Of course - I have tried to simplify the whole thing and tried to create a simple VI.
There are two combo boxes - the first one is to select the Model A or B and based on each model there are three different tests that can be selected for each model. Thus the user can select one among 6 tests. And midway through the test, if the test is stopped, the details of the test are saved to disk. When the application is launched next, the last run setup is recovered from the disk so that the incomplete test can be continued.
Since there are many places where the contents of the combo and String display are to be updated, I thought the property node was a simple way to do it.
( The actual application has 6 models and each model has a minimum of 5 tests and in each test there could be atleast 8 variants . You can imagine the extent of tracking mechanism required )
Just unzip the contents of the zip file into any folder and run. ( LV7 + WIN_XP )
Any idea to improve the situation is most welcome.
Raghunathan
Raghunathan
LabVIEW to Automate Hydraulic Test rigs.
