11-30-2015 11:52 AM
I have I problem. Maybe someone can tell me, how I can find time interval between two peaks in two continuos signal? In this case HM?cat
11-30-2015 11:56 AM
11-30-2015 11:56 AM
I would use Array Max & Min on each of your arrays. One of the outputs of that function is the index of the max. Subtract the two indecies and then multiply by the samples rate (assuming both are sampled at the same rate).
11-30-2015 04:55 PM
My real time signals looks like this.
11-30-2015 04:56 PM
And I need to find interval every time the peaks occurs.
12-01-2015 04:07 AM
Do I need shift?
12-01-2015 05:42 AM - edited 12-01-2015 05:44 AM
Assuming you have fetches of two continous wfrms..
What is your samplerate?
How do you capture the data?
Apply a a peak search on each wfrm part and calculate the difference ?
in your last data picture there are two white peaks .... how to decide which one to take?
Post your code and some real data (in a constant?) .....
