11-11-2004 01:46 PM
11-11-2004 03:52 PM
11-11-2004 04:17 PM
11-12-2004 03:33 AM
05-23-2015 11:45 AM
I am working on the GC problem myself. I have just started l I am working with the peak picking VI now. one thing is clear you need to load a typical signal from the GC to a file for development purposes. I would think that NI had crossed this bridge a long time ago.
The PP vi actually finds the positive an negative 2nd derivatives the peaks being the negative 2nd D's My plan was to integrate from positive 2nds and hope the threshold function works well.
Here is the integrator that I am trying to creaet a VI for
. http://www.chem.agilent.com/Library/usermanuals/Public/G1213-90120.pdf
Of course intigtaing from every minimum is going to be intersting. I guess it workes by size of the area under the curve but the intigtation funtions (it is my impression) of much of the chromatogrphy is much more compicated.
Finding min to the right and left of a peak is one way. Sounds simple enough the there is the slope (Derivitive ) of the cureve at FWHM
It seems incredable the the VI for the 3396 has not been produced. For any chart one would wish to run the volume under the curve is at least half the point... at least in our labs. Retention times are nice. Then the peak volumes need to be added and %'s worked out.
The grand finale is reporting the peaks by retention time and volumes along with the chart and retention times.
The code exixts already but someone at Hewlett-Packard. i mean Agiient I mean.... keysifght is sittting on it.
05-23-2015 11:46 AM
I might try intigrating from valley to valley
05-23-2015 02:30 PM
11-12-2004 03:33 AM
I'm pretty sure they're no longer working on this.
05-24-2015 04:32 PM - edited 05-24-2015 04:33 PM
I am sure they have implemented it in every digital O scope they ship.
05-24-2015 06:38 PM
How many O scopes do you think BEWIN has shipped?
