08-22-2016 06:44 AM
I have just started , so my question might be a little naive....
I have a data acquisition VI which I want to password protect using the input dialog VI.
I am attaching a sample program.
Is there any way to hide the characters that are being entered as "*********" ?
Thanks.
Solved! Go to Solution.
08-22-2016 06:49 AM
You can hide the characters by selecting Password display of Control:https://zone.ni.com/reference/en-XX/help/371361H-01/lvhowto/password_display/
-If you don't event want to show the asterisk (*), i am not sure about this.
08-22-2016 06:57 AM
Hi Uday,
Actually text box is not a control & does not have that 'password' option.
But anyway , I have been studying an old post where the solution has been provided by converting the express VI into normal VI.
08-22-2016 06:57 AM
Instead of using Express VI use your own sub VI with a string control and select the Password display by rightclicking on string icon.
08-22-2016 07:03 AM
The updated VI works......
08-22-2016 07:07 AM
Actually I want this to appear as a pop up when I run my main program , not as a control sitting there permanantly......that is the reason why I am using the dialog express VI.
Is there any way to make a string control appear as a pop up when I run my labview program....
08-22-2016 07:10 AM
08-22-2016 07:12 AM
call this vi in your main VI it will run as a pop up.
08-22-2016 07:31 AM
Thank you very much....
