02-17-2009 11:39 AM
02-17-2009 04:39 PM
Hi Tim,
I tested this with a LV 8.6 system with Win XP in it
Here are the results:
Reentrant Execution : 99ms, Non reentrant execution: 139ms
I am not able to replicate it. My conclusion that it is dependant on the system itself (dual core/single core etc.). Since I am not able to replicate it, I, unfortunately, file a report on this. I would like to know if your results match mine with the 8.6.1 system.
Thanks!
02-20-2009 10:48 AM
Hi Tim,
I just wanted to check in to see if you were having any luck with this.
02-20-2009 10:55 AM
02-23-2009 12:22 PM
Hi Tim,
I am glad to hear that this isnt being a problem for you. Like I mentioned before, the explanation for this behavior is probably due to difference in the system setup. As you are aware, a dual core system is going to behave differently than a single core system. I tried your VIs on multiple systems and was not able to replicate your behavior in LabVIEW 8.6 or LabVIEW 8.6.1. If there is anything else that I can do, let me know.
02-23-2009 02:01 PM
Thanks for your interest in this issue.
I'll let you know if anything comes up.
