Parallel loop data exchange
Hey guys,
I have a simple question and I hope yo ucan help me with an elegant solution.
I have 2 parallel while loops acquiring data @ 2Hz and 0.83Hz. Now I want to save the most recent value of both loops in a third loop.
What is the most elegant way to do this?
As I already implemented queues for data transfer, maybe you can include them in the solution 🙂 but it is not necessary. The problem with the queues is the point with the most recent data :)
kind regards
Slev1n
(2,907 Views)
Accepted by topic author Slev1n
Hi Slevin,
use notifiers!
Or lossy queues with a length of 1…
(2,905 Views)
Thanks for the fast answer,
one question regarding the "lossy queues". If I understand the help correctly, than using a queue with length one would cause the "queue write" function to wait until the place is free again. But as writing is faster my timed loop will fail to execute in the right time due to waiting for the "save loop" to read from the queue.
Does notifiers dont have this problem? EDIT: Ok, they behave different 🙂 I just read this here:
"Unlike the Queue Operations functions, the Notifier Operations functions do not buffer sent messages. If no nodes are waiting on a message when it is sent, the data is lost if another message is sent. Notifiers behave like single-element, bounded, lossy queues."
kind regards
Slev1n
(2,899 Views)
Hi Slevin,
when using lossy queues with the "Lossy enqueue" function your producer loop will not wait!
(2,875 Views)
@GerdW wrote:
Hi Slevin,
That is good to know!
(2,871 Views)
