Packed Project Library error: contains compiled code
I was trying to figure out how the packed library works for LVOOP, but face a wall with an error and don't know how to solve it.
i) I made a class 'Class 1', which I then put in a library called 'library'.
ii) I create a Packed Library and set the top-level library in the source files
iii) Once compiled and saved, I create a new project and add the newly create Packed Project Library to it. Second I add a newly create class, named 'Class 2'.
iv) I set the inheritance of the Class 2 as a child of Class 1.
v) select new VI for Override
vi) get Error 1035
What am I doing wrong or how to solve this?
(2,665 Views)
Accepted by topic author Harlequinade
The default setting for packing VIs into lvlibp's will remove the block diagram.
You must not remove the block diagram for dynamic dispatch VIs you are going to override.
hope this helps,
Norbert
Norbert
Expert: Geometry
(2,640 Views)
Thanks, that indeed did the trick.
Just to be clear for future users. Unset this tick mark in "Source File Settings":
(2,632 Views)
