04-21-2016 06:45 AM
I'm working on a project where I have to measure a square signal of 10KHz with a max of +3V and a minus of -17V
Somehow my program doesn't do this correctly(as shown in the printscreen).
When I execute the exact same measurements with an Agligent scope, I do get the correct measurements.
Can someone help me with this please?
Thanks in advance
04-21-2016 06:59 AM
How are you dividing the signal in order to go into the scope? The max range of the scope is -15V to +15V. So it will clip your negative side of the signal if you are not attenuating it. And your configuration has a probe attenuation of 10.
