the relay switch counts are only available for reading through the NI-Switch and NI-DAQmx APIs. The is intended, as the use of this counter is to track relay usage, enabling maintenance personnel to decide when to replace the card's relays. To reset the switch counts after relay replacement, open the NI-Switch Soft Front Panel and chose File » Relay Maintenance (see screenshot):
