06-29-2015 05:36 AM
I am new to labview, I would like to generate PWM signals of On time in the order of 0.1µs with duty cycle of 1%. I have seen sample programs for generating a PWM signal . I have NI USB 6251 hardware, Is it possible to generate the PWM of the mentioned requirement. I need this PWM signal to switch IGBT drivers.
If this cannot be used, kindly suggest me what hardware to be used _
Thanks in advance
Sriniketh
Solved! Go to Solution.
06-29-2015 05:45 AM
07-06-2015 05:29 AM
Thank you Gerd
Can I Use two counters separately for different pwm ?.
Also suggest me about the hardwares. I have USB 6251, In addition to this what would i need ?
07-06-2015 05:36 AM
