04-13-2006 02:10 AM
04-18-2006 03:33 AM
Here you can find an example:
09-25-2009 12:29 AM
Hi jurgen,
I recently was working with the PWM generation and i could guide you a bit. You can use DAQmx blocks. select frequency generation in the DAQmx start block. You can add controls to vary the frequency and duty cycle. Does this answer your question?
09-25-2009 12:44 AM
Hi Tigs,
i have already finished the PWM generation - it was 3 years ago and is working perfectly.
Thanks for your help!
Jürgen
05-06-2011 08:20 AM
hello..
i am trying to do the same task. i have to generate a pwm of varying duty cycle for a dc motor speed control. the sensor i am using is ZX-03 reflector IR sensor and data card is NI PCI 6221. i m using labview 8.5. i am a beginner. so please guide me how to go about it. also if u have vi for the process please share if u can...i need it to do asap.
06-22-2011 12:48 AM
i want togenerate PWM. will you please guide me? i am using labview 8.2 and NI cRIO-9004 i want to generate it using FPGA target. is it possible please guide me.
06-22-2011 01:10 AM
You need to first configure the channels in cRIO 9004 as AO or you can use a counter output if available.
You can get some more info from the following link: http://sine.ni.com/devzone/cda/epd/p/id/651
