PN sequence Generation
@Bagus77 wrote:
sorry sir , may i ask the components in your PN sequence . I didnt fint a component  right from  Reverse 1D Array . What the name component this?
That is "index array", resized for more inputs. Look in the array palette.
Also note that the image is a LabVIEW snippet. Drag it to your diagram, and it will turn into functional code.
Message 11 of 13
(750 Views)
Hello sir. Can you send the program you drew in 'Vi' format? I guess I can't find the modules you are using because the version has changed.
Message 12 of 13
(363 Views)
As mentioned, the image is a "snippet". Drag the image to your desktop. Then drag the image to the block diagram
of a new vi.
Or you can try this new and improved version attached.
In this version, a change to the feedback "taps" produces a Maximal Length sequence.
For 8 bits this will be 254 unique values (everything but all zeros).
Help the forum when you get help. Click the "Solution?" icon on the reply that answers your
question. Give "Kudos" to replies that help.
Message 13 of 13
(344 Views)
