07-14-2016 08:37 AM
07-15-2016 04:40 AM
Hi friend! Did you see my last post? I can not find the update rate in Labview 😞
I thought as well with DataSocket pallete... You think I can achieve with that?
Thanks a lot!
07-18-2016 02:48 AM
I have worked hard this weekend in this and I think that the problem can be that i am loosing data in the comunication.
Because the PLC variable is from 0 to 500 (a timer) so 1,2,3,4,5....500.
But Labview sees maybe 1,3,5,6,9,12,20,21,30,31,32,33,38,42..... So for that reason I am doing osmething wrong...
Can anybody help me?
07-18-2016 03:02 AM
Hello to al.
First of all thanks a lot for reading this post and being able to help.
I am communicating a PLC with Labview via NI OPC Server.
I have a variable which is a timer in PLC. from 0 to 500 ms (1,2,3,4,5,6,7,8..........500)
I communicate good PLC and Labview but the problem is that I loose data on the way... because Labview does not see 1,2,3,4,5,6,7,8,9,10...500 because maybe it sees 1,3,7,8,9,12,15,20,25,28,30,35,42.....
So for that reason my app works wrong...
I have tried to use datasocket and put UpdateRate tag in 5 or 10 ms... but it works more or less in the same way.
Any idea for improving that or help??
Thanks a lot!!!!
07-18-2016 04:31 AM
07-18-2016 04:38 AM
Ok, if you can help me...
Regards.
