03-02-2010 09:07 AM
03-08-2010 12:29 PM
I tried what you suggested. I input signals from AO0 and AO1, and used APFI as trigger signals (the same signals from AO0 or AO1). I did get trigger triggered. But the signal acquired is not what it should be. It should be a squar wave last 1 second. I got several sharp spikes.
For checking, I input just one signal AO0 or AO1, and used APFI as trigger channel. Trigger signal is same as AO0 or AO1. Everything is fine. I got what I should got.
Still I have problem for acquire two signals at the same time with reference trigger. I am thinking, this card has so many inputs. It should work with two channs.
Please advice.
Liming
03-08-2010 12:42 PM
Hi Liming,
I'm not 100% sure that I follow what you are doing. Is the following procedure correct?
-Connect AO0 to one of the AI Channels
-Connect AO1 to another AI Channel
-Connect either AO0 or AO1 to APFI0
-Output Square Wave on AO channels
-Use Analog Triggering off of APFI0 to acquire on both AI Channels
If that isn't the case let me know. Could you post a screenshot of the spikes you are seeing and confirm your connections?
Best Regards,
03-08-2010 12:54 PM
What you said are right on the connection. The above is what I see on the screen. I can not get into the measurement system today. I draw what I see per memerization.
Thank
liming
03-08-2010 01:56 PM
Can you please attach your code and a connection diagram when you have the chance.
Best Regards,
03-09-2010 08:04 AM
Here is the program I used for acquiring data from 2 channels with third one APFI as trigger. Please check it.
Liming
03-09-2010 11:36 AM
Hi detech,
The connection diagram would be also helpful, as well as a screenshot of how your front panel is configured. It would be helpful to know the following information:
Also, it woudln't hurt to post the screenshot after you've ran the test so we can take a look at the actual signal.
Best Regards,
03-09-2010 12:52 PM
Trigger source: APFI;
Chan : DEV1/AI8;
Chan: DEV1/AI0;
Input config: RSE (which is only one working wright)
03-09-2010 01:39 PM
Hi detech,
The code works fine on my system (using APFI0). This is the result I get:
The AI8 channel I just left unconnected--the sawtooth present is a result of ghosting.
This is how I have it connected:
Could you please provide the same information (screenshots of both the measured signal as well as how you have your signal connected). I'd like to offer some advice but I don't really have any information to work with at this point.
Best Regards,
03-09-2010 01:50 PM
I should add that I did make one change--you had configured an Analog Window Trigger when it sounds like you wanted an Analog Edge Trigger.
Now that I think about it, this might explain the behavior you were seeing. It was a bit confusing since the labels on your controls corresponded with those that would match up to an Analog Edge trigger.
Anyway, try changing the polymorphic trigger VI as follows:
Best Regards,
