05-04-2017 11:32 PM
as the topic shows, I am sure its exact meaning. as my understanding: it looks like "downsampling" function. a series of data will be re-sampling with dt: 0.25ms, with a sampling number: 1ms integration time.
1) I need your confirm my understand is right;
2) for the x.lvm format stored data, how?
Thanks in advance
05-05-2017 01:03 AM
when I saw express vi : re-sampling.vi, it only mention when re-sampling, how to get the secondary raw data from the first round raw data by linear, forced, sampling bar and FIR filter. how can I use RMS with integration time 1ms block of the first round raw data as the secondary raw data?
05-05-2017 01:18 AM - edited 05-05-2017 01:18 AM
Hi emckiller,
I think it's very hard to follow your sentences without having any example VI provided by you…
Could you please attach a VI with some example data? Can you explain the desired output signal?
Can you explain the connection between Resampling-ExpressVI, "RMS with integration time" and LVM files?
What is "1st round raw data" and "secondary raw data"?
05-07-2017 06:03 AM
its correct saying: Time overlapping of 75 % means e.g. for 1 ms integration time a 0,25 ms time interval between successive windows.
