06-18-2014 09:52 AM
Hello All,
I need some help outputting 4 different analog signals from the PCI 6711 board. I plan to use the function waveform vi from the analog generation pallette. My goal is to be able to enter in the 4 necessary functions, there sampling information, and then output them from the four available analog outputs available on the board. I've seen the example code for outputting across multiple lines, but it doesn't seem like it is able to create unique waveforms across the outputs, they are all the same waveform. I've attached what i thought would work, but i can't get my number of lines in data to match my number of lines in task.
Solved! Go to Solution.
06-18-2014 10:24 AM
Look like you're using the wrong Write function.
You should be doing N Channels N Samples.
06-18-2014 10:30 AM
More specifically, choose the polymorphic instance of Analog->Multiple Channels->Multiple Samples->1D Waveform.
Your current instance that you chose is for just a single line.
