02-23-2015 03:01 AM - edited 02-23-2015 03:21 AM
My phase difference (phi) value is not being updated if I change my input phase values. Everything else is being updated while the looping is running. I have to stop and re-run the vi just to update phi value.
Can someone please help.
Solved! Go to Solution.
02-23-2015 07:28 AM
The signal generators only look use the Phase input on reset. So if you want the phase to be able to change, you have to reset the signal generators.
02-23-2015 06:45 PM
Thank you so much. How silly of me lol to not be able to spot this.
I set reset signal = 'True' and now all the values update perfectly.
Thank you for your help.
