I am currently trying to automate a testing procedure using LabVIEW that requires the user to select the test from a drop down menu (Ring) and then clicks a button to start the test. When the button is pressed an 'open file' window appears asking for a name to save the file as. This all works fine the first time it is run, but i need to be able to stop the current test, select a new one, and then choose a different filename to save it as, without having to restart the program.
I am currently using a timed loop (as the test is time specific) and case statements for each individual test routine. I can only think of 2 ways to implement this, the first works only once (asking for a fliename when the program is first run), the second repeatedly asks for the filename each time the loop frame executes.
So the process is: select test - click button - chose filename - stop test - select new test - click button - choose new filename - etc.......
