07-25-2011 02:03 PM
07-25-2011 02:20 PM
What URL are you providing? Is this an absolute path or a relative path? If it's a relative path are you aware of this: Why Does My Executable Not Work When Using the Current VI's Path Constant?
02-09-2015 07:35 AM
Nope, not SP3 issue...
Guess what?... LabVIEW issue (again). "Open URL in Default Browser.vi" calls a DLL that is starting to not work anymore. My customers are now using IE9 and are having the same problem. NI's support pointed me to check some registry keys that aren't valid anymore.... Then told me to use a .NET call to launch the default browser: worked for a while, but then customers started having issues (apparently the .NET call invokes IE, **IF** IE is the defautl browser. If it is not, then it fails to launch the default browser.
No solution yet.
02-09-2015 08:01 AM
No solution yet.
Well, whoopty doo. IE9. Now that is cutting-edge. Not.
Maybe the registry keys don't exist anymore, because your customers are using antiquated software. Or maybe it is something else.
02-09-2015 09:07 AM
The easiest solution is to use a command shell call: Start "[url]"
/Y
04-27-2015 08:01 AM
I am using the block Open URL in Default Browser.vi (Labview 2013). i want after the browser open my URL close it automatically after few seconds . Please can any one help me?
Best Regards
04-27-2015 08:32 AM
What is the purpose of opening a URL to only automatically close it a few seconds later?
04-27-2015 05:44 PM
Hi i want to execute an url by opening it in browser to send data. this task will be done each 30 secondes so we will get after 5 min par exemple a lot of of browser open . his is why i want after i get the information from the url i want to close the browser to open later another one 🙂
04-28-2015 03:05 AM
Use the HTTP Client VIs to send your data to the URL. I'm assuming you're using some sort of GET parameters in your URL to send your data.
