07-30-2012 11:05 AM
I have html help files created with RoboHelp. Everything works fine except when I want to select a topic (Tutorials.htm in my case) to programatically display that is not the Top-level Online Help page (Main_Help.htm). The "Control Online Help" function seems to be the answer but the sub-topic is never displayed, only the top level. Any advice is appreciated.
Solved! Go to Solution.
07-31-2012 02:52 PM
The LabVIEW help document for the Control Online Help function indicates that the "Path to the help file" input can have a .chm or .hlp extension. Can you try creating a .chm instead? I built a similar block diagram, but used a .chm, and it performed as expected.
07-31-2012 04:04 PM
Doug, I think you're right. After lots of digging, I ended up with a chm file. It just doesn't look as nice as the html. But it works
