05-22-2017 11:18 AM
Dear All,
Is it possible to open labview version 5( older versions) in the current labview 16 versions. I have a couple of files to analyze.
Have a great summer!
Solved! Go to Solution.
05-22-2017 11:25 AM
Unfortunatelly, it's not possible. You could post your VIs to createn new topic here, so someone can convert it.
Sincerely, kosist90
05-22-2017 11:27 AM
Thank you for your reply, kosist90
05-23-2017 07:00 AM
The latest version that can open V5 seems to be 8.2, you can download it and use it to look or resave as 8.2. v8.2 should be able to open in the latest version (atleast 2015 could open it according to a matrix i saw).
Of course, getting it converted through the Conversion thread is an easier solution, but if you have several the above suggestion should work.
/Y
05-24-2017 11:17 AM
