07-10-2014 03:02 PM
I have a channel which gets its signal from a Hall Effect Sensor connected to that channel, and this channel signal goes into my DAQ device. Also, I have a Boolean button that associated what that channel. I am trying to code my application such that when that channel signal is 'Open", that is when there is nothing coming in to the DAQ device from that particular channel, then the Boolean Button on my Front Panel should start Blinking.
Folks, I would appreciate any coding steps or example vi if really possible from anyone.
07-10-2014 03:30 PM
07-10-2014 03:37 PM
Thanks for your response, even though I wonder how your series of questions is of help. Just to asnwer your questions: I don't understand what you mean by what I have done so far. In MAX, I have my Input Voltage settings as from -10V to 10V, and also hard configured on my DAQmx function that is on my Block Diagram. Again, I don't understand by the differences between the two conditions.
Yes, I have taken series of Free tutorials, but I am not expected to know everything about LabVIEW after taking Free tutorials. Once more, I don't understand by your basic condition paletter (i.e gt, lt, etc)? comment.
Of Course, I know what a Case Structure Statement is and how it works. Yes, I have looked at the Blinking Property Node of a Boolean Button and have used it on my application in the past.
07-10-2014 03:53 PM
