04-03-2013 09:38 AM - edited 04-03-2013 10:06 AM
The program has a switch which toggles the speed of the flashing LED (slow/fast flash) and I want to know how would I include an on/off switch for the LED?
Where the on option is default and the off option stops the flashing and the program should run continously. Do I use another case structure for this switch?
04-03-2013 11:24 AM
Boolean AND function between the wire that you currently have running the LED and the result of your POWER switch will do the trick very simply. Two versions attached- One using the variable format you started (which is frowned upon) and one using property nodes.
I also added a way to stop your WHILE loop. VIs should have a way to terminate themself. The toolbar Stop Sign is an "Abort" function and should be used as a last resort.
Jeff Zola
