10-24-2014 03:12 PM
10-27-2014 04:24 PM
Hi
I uploaded the error for your reference
Thanks for your reply
10-27-2014 05:05 PM
04-29-2015 12:54 PM
Hi, I know this is an old thread but it seems this is the right place to ask question about Ocean Optics Spectrometer. We have several OO spectrometers, all externally triggered. The external trigger often changes its pulse trigger rate, and when it does, OO spectrometer gives me an error message, "Instrument not synchronized properly. Power cycle instrument". Our system will be all automated and will not easily be accessible to power cycle the instrument. Is there a software command to power cycle/reset the instrument? I couldn't find the command from neither their manual nor LabVIEW driver.
Thanks in advance.
04-29-2015 03:25 PM
04-29-2015 06:27 PM
Hello Albert,
Thanks for the reply. The init gives a standard visa error if empty resource name is passed in. I guess I must have the newer driver. So, the error message must be valid. It being said, is there a command to reset the spectrometer to fix this error message? Or hard power cycling (unplug) is the only way.
Thanks!
04-30-2015 02:09 AM
Hi Tgif,
the alternative would be using the proper instrument driver. The OmniDriver does not care about the external sync rate and if i am honest, i have not seen a need to power cycle the instrument with OmniDriver in the past 5 years. The "NI driver" bypasses our interfaces and talks to the communications chip directly. Feel free to touch base directly with me (oliverl@oceanoptics.eu) if there are questions concerning the OmniDriver.
05-01-2015 03:34 PM
02-19-2016 10:37 AM - edited 02-19-2016 10:38 AM
I am having driver troubles with my HR2000+ using the NI-VISA USB drivers. I'm at the end of my rope.
I have searched high and low for answers and implemented everything relevent. For example, I know the difference between the OO drivers that come with OceanView, and the signed LABVIEW drivers that are available for download from NI. I can install either one with ease. However, when i use the hr2000+_vista.inf, I still cannot get my device to show up in NI-Max. The most frustrating part is that I had this working almost a year ago and developed software around it, which is now useless.
Any suggestions on how I can completely wipe all driver information and 'start over' so that when i plug in the hr2000+ I can install the NI _vista.inf (assuming that theres some kind of driver issue..) Thanks in advance guys.
02-19-2016 12:21 PM
Can you try to make your own INF file instead of the ones you have there? Or did you already do that?
See this guide:
http://www.ni.com/tutorial/4478/en/
