05-18-2017 02:04 PM - edited 05-18-2017 02:13 PM
@crossrulz wrote:
Personally, I would probably use the Match Pattern to find the = and then convert the After String (value) and keep the Before String (name).
Just like I had posted in Message 6.
05-18-2017 02:41 PM
This seems to be working well. I am having an issue with the decimal accuracy, I am only getting rounded numbers to 2 decimal points. I have something that is as 2.5000E-5 and I want to read it as that, but it just gives 0.
05-18-2017 02:45 PM
Sounds like a display issue. Right-click on your indicator and go to Display Format.
05-22-2017 11:36 AM
I have one more issue. I am attaching an image of just a snippit of code not working right. When I run this I get error code 85 that the input string does not contain data in the expected format, even though this works if I get rid of the rest of the text and only have the line IndexedValues =1.0002E-4
05-22-2017 12:23 PM - edited 05-22-2017 12:26 PM
Again like in Message 6 - Use the Match Pattern.
You are not handling all of the information before your search string. Using the Match pattern will lump all of the data prior to the match under output a. If the data will sometimes have a space before the numeric value, add a Trim Whitespace after output c of the match pattern.
