12-11-2015 01:07 AM
Hello, everyone.
I am now programming for a teststand. The old program has 7 module and is programmed with the traditional programming method. Now I have programmed two module with the OOP and want to replace the old module with the new. The main program, which controls the 7 module, should also be changed. Is there something that I should pay attention to?
12-11-2015 03:06 AM
Hello alre,
You should read this white paper.
http://www.ni.com/white-paper/3574/en/
Have you ever developed in LabVIEW OOP? Else training could be a good idea!
There some webcast you could also watch
http://www.ni.com/webcast/1513/en/
http://www.ni.com/webcast/1718/en/
Good luck.
12-11-2015 03:21 AM
I have learned the Labview OOP Kurs and developed two module with OOP, thanks for the Links
12-11-2015 03:33 AM
Not really- treat class objects like a cluster with limitations on where the fields can be accessed and you won't go far wrong.
12-15-2015 07:44 AM
I have finished to replace the old program with the new OOP module. It will then be tested on the teststand.
