02-20-2015 09:09 AM
Hi everybody out there....
Does anybody know if it is possible to call a method using an OPC-UA Client (DSC module). I have to do this, but I cannot see any methods in the browser tool although there are some implemented in the node class (server side).
Regards
Thermo
02-24-2015 12:52 AM
Hello Thermo,
it seems that this feature is not implemented at the moment.
02-15-2019 08:10 AM
Hello guys,
do you have an idea is such a feature has been implemented now?
09-08-2020 02:14 AM
I have the same problem! Or does somebody know a work around to call OPC UA methods over LabVIEW?
09-08-2020 02:44 PM
Hello to all,
i used a workaround. I created a OPCua client and use the event subscribtion. In the event structure the method will be placed.
http://zone.ni.com/reference/en-XX/help/376230B-01/opcuatool/using_opcua_clnt/
Hope this helps a little bit.
09-10-2020 09:38 AM
@Duffy2007
Did I understand that right, that you first create an Event Subscription and then add the methode to the Monitored Event Nodes? The methode will create an event if it's executable?
And how you call the methode? With the Respond Acknowledgeable Condition VI?
regards,
Dominik
09-10-2020 02:42 PM
Hello DominikZ,
Yes you are right i created a dummy client for this and i used this architecture and placed the method in the event structure.
You have to change the subcription time. I set it too 2ms for checking the change.
09-15-2020 11:00 AM - edited 09-15-2020 11:06 AM
Thanks a lot.
But did you use the the Respond Acknowledgeable Condition or the Enable Condition to respond (call) the method?
And if you use the Respond Acknowledgeable Condition what do you have to send as a request method? Confirm or Acknowledge
09-15-2020 03:15 PM
Hello DominikZ.
sorry i did not used this functions, because i want an event based solution.
