03-11-2015 09:12 AM - edited 03-11-2015 09:13 AM
I search an OPC UA Client for TestStand 2012. I have downloaded the DSC-Module for LabVIEW 2012 for evaluation. Now I have tested the OPC UA Client with three OPC UA Servers, but only with one works the communication.
1.) OPC UA Server from my company (in development) -> Error code -356617 (Screenshots OPC_Client/Server_1)
2.) Softing OPC UA Demo Server -> Error code -356605 (Screenshots OPC_Client/Server_2)
3.) Unified Automation UD Demo Server -> works (Screenshots OPC_Client_3)
What could be the reason? Thank you for your help.
Regards, Sven
Solved! Go to Solution.
05-08-2015 02:45 AM
the result was that LabVIEW / DSC <= 2014 has connection problems without Security Mode. The Support told me that with LabVIEW / DSC 2015 this problem will be solved.
Sven
08-10-2016 04:43 AM
ok now we try with Labview 2015 and connect as OPCUA Client to an CODESYS V3 OPCUA Server.
Anyone know how to setup the browse path here?
08-10-2016 05:41 AM - edited 08-10-2016 05:47 AM
CDSUA : Do you reply correct topic @@?
08-10-2016 06:18 AM - edited 08-10-2016 06:38 AM
probably, sorry not but i did not find the correct entry point to do this / start the post?
07-06-2021 08:56 AM
I am encountering the same problem. Were you able to find a solution to the path?
