P.J.,
Thanks for the response! Yes, I could build large For/Next loops and read
and write individual sequential elements that way. But it wouldn't be very
elegant, and I'm betting there's a way to do block reads and writes.
If I don't turn up a "block" OPC call, I will probably follow your advice.
Andrew Russell
San Diego
pjtanz wrote:
>Hi Andrew,
>I'm not sure how to write blocks through RSLinx, but if you are able
>to write a single block, it should be relatively simple in LabVIEW.
>If you include all of the blocks that you wish to write in an array,
>then you can pass the array into a For Loop. With auto indexing
>enabled, the loop will automatically iterate once for each element of
>the array. You can use this feature to use the DataSocke
t write VI to
>sequentially update each of those items on the PLC.
>I hope that this helps.
>Regards,
>P.J.
>National Instruments
AuthiMini de Espana
