12-29-2014 10:16 AM
12-29-2014 10:39 AM
No image attached. Which example are you looking at?
12-29-2014 12:05 PM
Yes, what you are describing sounds like a class. The VIs in a class can be protected so that other VIs can't use them. They don't have to be protected though. See the access scope documentation here: http://zone.ni.com/reference/en-XX/help/371361L-01/lvdialog/c_item_lib_page/
12-29-2014 12:39 PM
12-29-2014 12:52 PM - edited 12-29-2014 12:53 PM
Ahh, those are not a class. Those are members of a class. If you use those VIs and typedefs in a place that isn't allowed to access those VIs you'll get a broken arrow. This can potentially save you from a run time bug.
Did you see the access scope link I posted above. It explains where the protected VIs are allowed to be used.
12-29-2014 01:07 PM
12-29-2014 02:31 PM - edited 12-29-2014 02:32 PM
In this example a board is made of components. You can think of "Get Components" as asking the object a question about what it has. It doesn't make sense to ask a component what it has.
Some things that might be confusing:
There's no reason to have this folder. There's other protected VIs that aren't in a "protected folder". I think the reason they made the folder is just to show the developer that Component Orientation and Position.ctl is only used in "Get Component".
You might be wondering if Get Components should be protected. I think it's up to you and your style. Do you think more warnings should "break the run arrow"? If so, protection will break lots of run arrows
