11-27-2007 09:00 AM
11-28-2007 11:43 AM
Hey gundam01
The best way to do this is redefining the ROI orientation by searching a good pattern so you can reference your ROI to that pattern and change your coordinate system orientation. Another workaround could be to rotate the image itself so that the text is readable. There is a Vision Assistant step that allows you to do this, the Geometry Step, but it does not have a terminal in which you can indicate the angle to rotate. In order to do this you can use the Run LabVIEW VI step, which you can pass a value to rotate the image a specified angle. You can find this angle using the pattern matching, in your case maybe you can search for specific holes positions, and then use the angle of that pattern to rotate the image. This could work so you can make your script more robust.
11-28-2007 01:23 PM
07-05-2015 03:51 AM
Dear gundun
I have the same problem. If your problem is solved, Please explain!
Thank you
sincerely
