04-15-2014 12:45 PM
I am working on an interface for an HP8722C using a GPIB connector. I have a lot of the functions working correctly but I have hit a roadblock when it comes to the number of points in the sweep. All of the points work great up to 401 then 801 and 1601 points gives me an error and crashes the whole system. I am thinking that it might be a timing issue, like it doesn't let the function finish plotting before trying to collect it. Is there a way to make it wait a little longer to collect the data, like insert a delay or something?
04-15-2014 01:53 PM
04-15-2014 01:55 PM
I actually just figured out I needed to add a timeout box before the spot that is causing an error and increase the timeout time.
04-15-2014 01:57 PM
04-15-2014 02:00 PM
It may not be elegant but it works.
04-15-2014 02:17 PM
04-15-2014 02:25 PM
What do you recommend?
04-15-2014 02:42 PM
04-15-2014 02:50 PM
Plug and Play - not using OPC
04-15-2014 02:54 PM
