09-21-2016 01:01 AM
While working in LabVIEW in order to generate a PWM Signal, we need a DAQ Assistant either to generate or aquire a signal. In this DAQ Assistant we need to select the hardware assesories like NIPXIe 6535 or 6711 or 6236 to out the signal. During this process only NIPXIe 6535 cannot be recognised. It has been a serious issue, so please suggest me with the possible remedies as soon as possible.
Solved! Go to Solution.
09-21-2016 02:30 AM - edited 09-21-2016 02:31 AM
09-21-2016 04:34 AM
As requested I have provided the required screnshots. The files are attached below.
09-21-2016 04:36 AM
Other screenshots are attached below.
09-21-2016 04:47 AM - edited 09-21-2016 04:49 AM
You should remove the LabVIEW screenshot, you revealed your licence number 🙂
About your problem: so you have LabVIEW 2011, and DAQmx 9.3.5. Are you sure the module 6535 is physically connected to your system, and works? Can you try it in another slot/PC?
I think you should also install the latest DAQmx driver (9.3.5 is really old version!) compatible with your LabVIEW 2011 (no idea if this can help, but you can give it a try). The latest DAQmx driver for your LV version is DAQmx 14.5.1 ( http://digital.ni.com/public.nsf/allkb/B0D5630C0A50D5C6862578E800459248 ). You can download it here: http://www.ni.com/download/ni-daqmx-14.5.1/5271/en/
EDIT: and why did you mark my post as solution? You problem is not solved yet 🙂
09-21-2016 05:09 AM
thanks for clarifying the mistake
