09-07-2009 05:27 AM
I have the followig problem. When I open a certain llb it doesn't show the included VIs.
Does anyone know what causes this problem. I'm using LV8.5
Thanks Bastian
09-07-2009 05:32 AM - edited 09-07-2009 05:32 AM
09-07-2009 05:42 AM - edited 09-07-2009 05:43 AM
09-07-2009 06:04 AM
The file size is about 5MB. The problem only occurs at this llb. Other llbs still work.
09-07-2009 06:10 AM
09-07-2009 06:14 AM
I don't think so. The file is in a certain directory since two month.
Yesterday I still could open the VIs of that llb. I think the file is damaged.
My last back up was one week ago.
09-07-2009 06:24 AM
09-07-2009 07:12 AM
03-17-2015 07:31 AM
I had the same trouble with an LLB file (in LabVIEW 2013). However, I could reproduce the failure:
I wanted to include the VIs of the LLB in the palette menu, so I set a link to the LLB (in the palette editor).
This worked fine (but of course, all the VIs in the new sub-palette were placed in random manner).
As soon as I modified the new sub-palette (for instance, repositioning of a VI), the LLB was corrupted.
Also other modifications (changing sub-palette name, removal of VIs) leaded to a corrupted LLB. So:
NEVER LINK TO AN LLB FILE TO CREATE A SUB-PALETTE; ALWAYS USE A SEPARATE MNU FILE!
I hope, this might help some of you...
Cheers!
