02-28-2009 11:16 AM
I think that now I am actually getting somewhere. Hopefully a couple of last questions.
On the spec sheet, when it refers to input voltage sensitivity, that is the amount of voltage needed from a given voltage to enact a change of measurement. Is that statement true?
For instance the USB 6510 model has a minimum input voltage range of -200mv to 200mv, but it also shows an input sensitivity for that range of 4.8uV. If I do a little math however, at a 400mV range with 16 bit resolution, I calculate a 6.1uV voltage sensitivity if my first statement was indeed true. Whats up with that? 16 bits means 2^16 right or (65536), at a voltage sensitivity of 4.8uV I would have 83333 step increments of measurement, a number somewhere between 16 bits and 17 bits. I will have to conclude that my first statement is not true unless I am not using all the variables, 16 bit is actually a rounded off number, or I totally missed the meaning of the spec sheet statement.
Then I also have problems with the Range Accuracy spec, it states that the accuracy is 88uV. Can the accuracy really be 18.3 times the increment needed to change a voltage measurement?
So in conclusion here goes, does this all mean from the spec sheet that the minimum input voltage range is from -200mV to 200mV with a change in voltage measurement for every 4.8uV increment, and it could possible be giving a false reading up to a value of (88uV / 4.8uV=) 18.3 increments of voltage.
02-28-2009 11:28 AM
03-02-2009 03:54 AM
If you want to spend 1k for the more sophisticated USB DAQ you might give the 6009 a try first...
You don't really need a TC to read 400F a selected NTC will do the job. More signal at the cost of linearisation.
You didn't mention your soldering skills ;-), however a good source for load cells are the $15 electronic kitchen balances, professional stuff with a 0-10V output might eat up >50% of your budget 😮
And while we are at it, why not add a vibration sensor? 'cheap' MEMS would be easy to hook up, but are only low frequence ... (ab)use a piezo disc from a loudspeaker ??
Sounds like a nice project for a highschool in your region.
03-02-2009 08:19 AM
You need an RC engine dynamometer stand.
03-02-2009 08:26 AM
03-02-2009 08:38 AM
03-02-2009 08:47 AM
03-02-2009 10:42 AM
Hello Ragewizard,
I just wanted to clear up a few of your questions that might not have been answered yet. A background, for anyone unfamiliar, when you refer to the card accuracy, it is just a measure of how close to the actual reading you get. Ex: If we feed the 6210 a signal of 100 mV, this card will read within the range of 99.912-100.088 mV.
And with the sensitivity, it is a measure of how much a signal must change to register a different value on the card. Just because the sensitivity of the card is less than the absolute accuracy, does not mean that the card will not track the actual signal. So, if your signal increases just 5 µV, your card will register the difference and will most likely go up by 5 µV, but the accuracy of the measurement may still be off by as much as 88 µV. I hope this clears up any confusion you might have.
03-02-2009 03:34 PM
03-02-2009 03:41 PM
