04-18-2007 08:29 AM
04-18-2007 11:19 AM
Just to check, I removed the shared variables from the VI.
Without them, the GUI starts right up and works fine with no delays.
Of course, I cannot send data to the deployed serial write vi on the RT to send a message out on the serial port of the cFP-2120 controller without them.
So now that I'm convinced its the variables at fault, where do I start to troubleshoot?
04-18-2007 01:25 PM
The variable library is deployed on both the local host and the remote.
Variable manager is able to see them and veiw the data within them.
The variables on the remote are bound to the variables on the local host.
The main VI still hangs up when I run the GPS message simulator as a subvi.
GPS message simulator still works fine as standalone.
04-20-2007 09:12 AM
04-20-2007 09:22 AM
I don't get anything when running in highlight modem, just a blank white window.
I let the original run last night while I went home. It finally had come up and was running this morning.
After days of working with bindings, etc I finally started hacking off sections of my main VI today. It eventually started working.
I apparently have too much baggage or a conflict on the main vi structure.
I'm dealing with nearly 40 indicators/controls used to monitor or modify simulation values for an avionics simulator.
Clearly I'm not being effecient in memory management.
I do have multiple while loops monitoring and sending data.
