Network Published Shared Variables Example
apart from what I meentioned in my post,  did you try TOOLs\Shared Variable\register computer?
hope this can help
xg
Message 21 of 29
(1,161 Views)
Yes. It still doesn't work.
I tried it uncompiled (both comptuers have LV 2011). It doesn't work uncompiled either. When running in development env. it shows a window witha progress bar for the deployment of the variable. However, it doesn't update.
Danielle
"Wisdom comes from experience. Experience is often a result of lack of wisdom.”
― Terry Pratchett
Message 22 of 29
(1,142 Views)
I have not used the aliases files.  Can  you post your example code, and I can try them on my two PCs, I only have LV2012.
Cheers
xg
Message 23 of 29
(1,138 Views)
I used the example code given with no change. Both computers had the full example. In one I ran Publisher. In the other I ran Subscriber.
I did deploy and register computer in both computers. I also added all IPs in Tools\Option\VI Server\Machine Access list.
Danielle
― Terry Pratchett
Message 24 of 29
(1,134 Views)
sorry can not understand why it does not work for you.
by the way, can you ping both PCs?  what is "ipconfig -all" display for two PCs
cheers
xg
Message 25 of 29
(1,130 Views)
Is there anything specific I should look for in ipconfig -all?
Could the problem be that both computers are on a local work network? Maybe the sharing is suppressed in some way?
Danielle
― Terry Pratchett
Message 26 of 29
(1,096 Views)
can you post your ping result so that I can have a look ?
cheers
xg
Message 27 of 29
(1,073 Views)
Ping result (from 192.168.50.91 to 192.168.50.110):
Pinging 192.168.50.110 with 32 bytes of data:
Reply from 192.168.50.110: bytes=32 time<1ms TTL=128
Ping statistics for 192.168.50.110:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 0ms, Average = 0ms
IPconfig -all on 192.168.50.91:
Windows IP Configuration
Host Name . . . . . . . . . . . . : danielle-HP8100
Primary Dns Suffix . . . . . . . : Nanonics.co.il
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : Nanonics.co.il
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . : nanonics.co.il
Description . . . . . . . . . . . : Intel(R) 82578DM Gigabit Network Connection
Physical Address. . . . . . . . . : 72-AC-C4-A7-16-FF
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe88::31c6:a4f7:92d9:7b8b%12(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.50.91(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : ‰…™Œ‰™‰ 14 Ž€‰ 2013 11:34:57
Lease Expires . . . . . . . . . . : ‰…˜‰’‰ 29 Ž€‰ 2013 11:34:56
Default Gateway . . . . . . . . . : 192.168.50.1
DHCP Server . . . . . . . . . . . : 192.168.50.6
DHCPv6 IAID . . . . . . . . . . . : 276344000
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-16-10-F0-5B-78-AD-C0-B7-12-FE
DNS Servers . . . . . . . . . . . : 192.168.50.6
192.168.50.4
NetBIOS over Tcpip. . . . . . . . : Enabled
all the rest is "media disconnected".
the %...and wierd stuff is because the date is in Hebrew so the font doesn't translate well.
Thanks!
Danielle
― Terry Pratchett
Message 28 of 29
(1,059 Views)
Sorry, don't know why it does not work for you.  Firewall off?
Can you try different PCs?   I only have LV 2012, if you can post your code I can have a go on my two PCs.  I don;t think there is a problem with the code but just in case.
Cheers
xg
Message 29 of 29
(1,046 Views)
