02-28-2013 02:05 PM
I am developing an remote panel application that have 3 vi's.
1 - Login vi => If username and password is OK, then the login vi add the Main vi to access list, and the user can access it.
2 - Main vi => Is the main code
3 - Supervisory Panel => Have a property node (RP.Conn.To.Clients), that searches (with a for loop, number of interations = number of online users), and compares the online users to a condition: if the user is controlling the Main.vi, if yes, I display the user information(IP, Status, Port) on the Supervisory Panel.
My issue is, I need to display also the username(inputed in Login.vi), togheter with IP, Status, Port, that are provided by Rp.Conn.To.Clients.
So i need to know if there's a way to attach the username string with the information provided by RP.Conn.To.Clients, in the same index, because my application will be accessed by many people, and I need to attach several usernames with the information that the property node provides, in the same index.
Any help will be appreciated, im stucked on this for almost a week!
02-28-2013 03:00 PM
How does your message relate to your subject line where you are asking about the Change All to Read menu choice on a property node?
02-28-2013 03:25 PM
Sorry for the error.
My idea was to input a value togheter with the property node, at the same index. Thats why i picked this title.
02-28-2013 03:36 PM
Not sure if this is what you meant, but you can change the read/write for each property on a property node individually.
03-02-2013 06:57 AM - edited 03-02-2013 06:58 AM
Hi
I think we will be able to understand better if you show some code.
Also, I still did not get why you need a Property node that doesn't have "Change All to Read" property (well, I also think that is not the property of a property node. it is an option on the propery node to set the Read/Write setting on the properties selected in the node).
Anyways, a look at the code might help.
