02-13-2014 09:23 PM
when i run the example of spartan 3e dirver for labview2012,it could't work,
An error occurred in the :Create Directory Recursive.vi->niFpgaBuildInstructions_Create.vi->niFpgaBuildInstructions_CreateFromBuildSpecPath.vi->niFpga_Runbutton.vi:3Create a folder. Can you help me?
02-14-2014 05:09 AM
hello sir,
since i have been working on the same thing and finding the same problem as it have been discussed in this discussion , so sir it is requested to you sir please upload the following driver again please ....please sir it will help me alot. please
02-14-2014 08:52 AM
CROBIN, welcome!
I have not seen that error before, but it seems that there was an issue creating a folder. How full is the disk/partition that is used for C:\ on your machine? I suppose it also could be a folder permission issue. It's been a while since I've worked on FPGA so I will defer to someone who's a bit more familiar.
02-14-2014 10:25 AM
sir i just want driver for interfacing the labview 2011 with FPGA spartan 3e startar kit...so please help me out in it. as i could not find this driver any where..
OR sir i have also labview 8.5 if the driver for this is awailable then you can please upload it. i will be very thankfull to you sir, and i will pray for you..i am facing alot of troubles in this regard.
02-16-2014 12:42 AM
Thankyou sir.
My computer c drive still remaining capacity 18G,But it still can not work .i don't know which folder permission should be change. I come from China,so Translation of the error is that Create Directory Recursive.vi->niFpgaBuildInstructions_Create.vi->niFpgaBuildInstructions_CreateFromBuildSpecPath.vi->niFpga_Runbutton.vi:3Create a folder.
Possible Cause
LabVIEW: Invalid input parameter. For example, enter the path to the operating system may contain characters not allowed for a path (for example,?, Or @).
compilation:\Shift_FPGATarget_Shift_jJ4Pe3ss8GA
I try to run the sample into the root directory of the computer ,but it could't work.
Could you provide Spartan 3e driver for labview 2011 for me, I want try it again.
02-17-2014 10:57 AM
Hey CROBIN,
First, I believe this is the driver that you are looking for:
http://digital.ni.com/express.nsf/bycode/spartan3e?opendocument&lang=en&node=seminar_US
Next, it sounds like the path that you are trying to use is invalid. Does the folder you are trying to create on your drive already exist? Are you trying to create a folder that contains characters that the OS does not allow?
Ryan
03-29-2014 09:32 AM
TJ G, would you please upload spartan 3e driver for LabVIEW FPGA 2011 on FTP again, i need it.
tks.
03-31-2014 10:11 AM
04-15-2014 09:12 AM
TJ G, I‘m sorry to tell you the time expired, would you please send it to 1-ricky@163.com, tks.
04-16-2014 04:10 PM
Hello Rickyyq,
The file is over 60MB in size. We are not able to email files that large. I have placed the 2011sp1 drivers for the Spartan3E back on our ftp site.
ftp://ftp.ni.com/outgoing/Spartan3e2011/
Best regards
